Brief Description: Electrical component mount assembly continued
Today I continued work on the electrical component mount. It was cleaned, abraded, alodined, primed, assembled and installed. I also fabricated a mount bracket for the essential buss solenoid.Then I fabricated fuel system fitting manifolds. While the primer was drying I also enlarged the holes in the rear spar for the push rod pass through.
Electical component mount assembled and installed
Essential buss solenoid mount fabricated and installed
